Transmission fluid level...
Hi.
- After a few days resting on a flat surface, engine off, and at ambient temperature, fluid pours out from the level plug a lot, not a tiny stream. - Starting from cold and idling, going trough all gears, no fluid at all comes out of level plug. - After running for an hour, getting home and parked level (hot), no fluid comes out at the level plug. Is this all normal ? Is there any symtoms of overfilled ? Is there any symtoms of underfilled ? Is it harmful running overfilled, worse than underfilled ? |
