-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Transmission Oil Temperature Light (https://landroverforums.com/forum/discovery-ii-18/transmission-oil-temperature-light-21299/)
Robmcin Apr 16, 2009 08:55 PM
OK, ran over to the other side of the river to let my son's dog out to go bathroom and when I left I got about 1/4 mile down the road and my tran oil temp light comes on... I go about mile to a parking lot to pull over and sit and wait like the manual says.. for about 10 minutes. Then I take off and real quick the light is back on. So I go to my daughter's house (about 1.5 miles and visit with them for a while, hop in light is out, 600 feet down the road light is back on.. then off, then on, then off... once I got out on the highway and up to 55, it went out and stayed out. I have the synth atf ordered to do the flush and fill.
I was not towing anything and it was only 60 degrees and I wasn't driving at high speeds.
Anybody?
Spike555 Apr 16, 2009 09:06 PM
You have a bad temp sensor, a loose wire or loose wire harness.
Unplug the wire harness and clean it then wait and see.
grussell Apr 16, 2009 10:35 PM
I had a similar issue and I had water in the plug on top of the temp sensor on the transmission line just behind the radiator. I had washed the engine and water got into the plug. Cleaned it with electrical cleaner and light was gone.
Disco Mike Apr 17, 2009 11:17 AM
Or, you have an actual over heat issue, I would lean more towards this then a bas switch, which will act differently when failing.
PM me your tel number and lets talk.
Robmcin Apr 17, 2009 01:06 PM
Mike
PM coming. The light has not come back on today. I am planning on getting the tranny flushed and filled with RP as soon as the filter/kit gets here from Atlantic British.
Thanks
Rob
Disco Mike Apr 17, 2009 02:45 PM
Rob,
Do not do the flush or the Royal Purple till we talk, you can prematurely kill your tranny by doing that.
Disco2Fever Apr 17, 2009 03:17 PM
Rob, will you please post a recap of what Mike says?
That's sweet that these things have tranny temp lights.
