Transmission shift point question
Old 06-29-2012, 07:32 AM
The ECU for the tranny has what is call adaptive memory, which may be off a little. Twice over the last 4 years, I have had mine reset and the tranny goes right back to shifting like a new one. Now I am not saying this is the case with yours, but a possibility.
Old 06-29-2012, 10:09 AM
microbc's Avatar
Thanks to all for your replies!
oilsptLR - Wow, your shift points are a lot higher than mine going into 3rd and then 4th.
Drowssap - I will run it in sport mode on my way home this afternoon and note any changes in the shift points.
DiscoMike - How does the transmissions "brain" get reset? Is this a dealer item or would disconnecting the battery for a period of time cause the system to "re-learn" its shift points?
It seems like this may be a normal occurance for the Disco transmission but it has definately changed the "feel" of how my truck shifts and I just wanted to make sure that there wasn't something major going on.
Thanks again to everyone!
Old 06-29-2012, 10:23 AM
A dealer or shop with a test book or something similiar would have to be used to reset the adaptive memory.
Old 06-29-2012, 06:12 PM
microbc's Avatar
Thanks for the response DiscoMike.
Could/would a bad XYZ switch cause this type of symptoms?
Thanks
adigerol77
05-13-2011 02:04 PM
MoMotta
09-28-2005 04:35 PM
mikemeyer0
Off Topic
08-14-2005 05:14 PM
traffictech870
03-23-2005 11:45 PM
Quick Reply: Transmission shift point question
