Transmission STILL leaking
Ok, FMS, t-case, diff's, all resealed and not leaking a drop. But the transmission pan is killing me. It's a new pan, and new gasket. (old pan was damaged due to a front drive shaft failure) The thing is STILL leaking, from the drivers side rear. To be specific it's leaking and dripping on the nuts for the drivers side and drivers rear nut.
What's the trick here? Should I resort to RTV? Is the torque value on the rave cd wrong? should I check the mating surface on the trans to insure it's level? |
If you tightened them to spec then go back and snug the leakers up a half turn a day until it stops.
It should only take one or two half turns to get it to stop, if not then there is something else going on with the gasket. |
Originally Posted by Spike555
(Post 143158)
Have you checked the flange for plumb? The driveshaft could have warped the transmission casing itself, not just the pan.
Originally Posted by gilder
(Post 143188)
I suppose if it's out I'm going to be looking for a new transmission case, or just a transmission I suppose. |
Or just try to RTV it.
Originally Posted by lipadj46
(Post 143266)
People seem to have good luck with RTV gaskets on oil pans.
I repaired my leaking front main seal 2 years ago with RTV.
Still leaking, will RTV tonight. I just love pumping all that ATF in. :(
