turn signal relay
Hello, driver side blinker relay needs to be replaced on my 2004 D2, I tried google to find a replacement but to no avail. Anyone know how much they go for? or have an extra one laying around, I havent called any part stores yet, wondering if they keep em in stock?
Not sure but take a look at this catalog, if nothing give Rovers North a call and they should be able to help you find the relay. Discovery II Electrical Switches and Relay - Rovers North - Classic Land Rover Parts
they is a swing down door under the wheel the directional relays and flashers are in there,
do you have the small yellow or black relay? you can swap the relay with one or two under the under hood panel |
Are you sure it's the relay? The switch is a common failure part on Disco's. There are a few post's on replacing the switch on this forum. The wiper switch has similar problems and many can be resolved by taking the switch apart and cleaning the contacts.
Thanks for the reply's, turned out to be a burnt out rear bulb, lol
| All times are GMT -5. The time now is 06:43 AM. |
