Ultragauge Installed, Temps and Codes
Installed my new UG this morning. I really like having the real temp and volt reading right there and being able to read and clear codes.
Temps are 194-198 driving around and 208 idleing for a few mins.
Have a 180 t-stat on order and will install when I get it.
Had Code P1300 which i think is Boost Cal Fault. Found it off a generic code site so if wrong please let me know.
Set the UG up to have O2 voltages displayed but I am not sure which is which.
Bank 1 Sensor 1
Bank 1 Sensor 2
Bank 2 Sensor 1
Bank 2 Sensor 2
So are the Bank 1 sensors before the cats? And the Bank 2's after the cats?
Could not find the O2 sensor info in the rave.
Thanks as always for any info.
Chris
Bank 1 Sensor 1
Bank 1 Sensor 2
Bank 2 Sensor 1
Bank 2 Sensor 2
Chris
I looked in the Rave and could not find anything on the O2 sensors but I'll try again.
Thanks
edit: that search tip works great Buzz. Thanks alot
All the rave engine codes are now in http://enginecodemaster.com
Have a look in there and it should help.
