UltraGauge readings
I'm a newbie, picked up a 2000 model last tues. I put the ultra gauge on it right away. It mostly hovers around 194 with lows at 188 and highs at 199.
It does have an interesting warm up though, when the vehicle first reaches operating temp, it will go close to 220 while stopped and at idle. I attribute this to the thermostat not operating quite right until it has become heat soaked. Since once the rig has fully warmed up (30 minutes or so) the phenomenon goes away.
I ordered a 180 deg thermostat fromatlantic British as well as some hoses, and fresh coolant. I will be servicing the cooling system within the week.
I'll tell you what before switching to the "soft spring" my heater would be capable of producing Africa like temperatures. It was unbearable at times. Yes, my heat takes alittle longer to produce warm air but I'm not complaining. I just switch on the heated seats and smile at my new lower operating temps
0304Disco
05-19-2011 03:18 PM
