Undetectable noise. front left wheel.
Hi again.
I still have a strange noise on the front left wheel , I have already changed , Steereng dampner , Wheel Hubs ( All 4 ) both drive shafts. and numerous ather things and the damned noise is still there. It increases when accelerating and turning to the right, it stops when not accelerating. I took it a work shop and told me that now I need new wheels and Shocks. That these is the cause of the noise. I am really running out of options , money and patience. Actually I thought of turning up the volume and forgetting about the entire thing and waiting for something to come off , but this car belonged to my grand father and he really liked it ( so do I Really ) and intend to bring it back to new condition , but still need to do the 60 K service....And getting a little desperate. LR Work shop ( called the house of terror in Mexico ) originaly told me it was the transfer case .... I have checked it and to my knowledge it is all good No sounds Leaks or anything. Perhaps I should do a check List of everything I need to do acording to priorities right ? What would guys consider as a priority ? Noise , 60 K service , Wheels , Shocks ? |
RE: Undetectable noise. front left wheel.
I would do the full service first (unless your tires are very worn). Who knows, changing the fluids might fix it (maybe power steeering, diff / tranfer case noise?). Can you describe the noise any better? Is the noise constant, rhytmic, loud, soft, metal-metal, scraping, cluncking, squealing, occur when actually turning the steering wheel or is itwhen holding it in a right hand turn? Shocks or sway bar sounds plausible but it depends on the sound.
What year and mileage?
No shocks, no wheels. Does it happen more when turning??
Disco 2003 67k.
Checked all fluids , Nothing aparent on Trany or Transfer Case. Noise is soft Metalic scraping. Happens when accelerating and turing to the right at 40+ MPH ( on left front Wheel ) also happens when road is irregular and increases when accelerating ... Also tends to wonder off on irregular roads or constant correction ( hands on wheel oll the time ). Wheels are worn unevenly , more on the inside ... they are KHUMO 255.55 r 18. Shocks are Custom LR. seem a little worn. Very hard on bumps or holes on road ( I believe this is normal right ?). Engine Oil . Air filter , seem new I have no history and havent checked anything else. LR Mexico has NO history on this car so I´m pretty much on your hands and will be bery thankfull if I can save some Money. |
Has any one looked at the front CV joints?
ORIGINAL: javoli001 Hi again. I still have a strange noise on the front left wheel , I have already changed , Steereng dampner , Wheel Hubs ( All 4 ) both drive shafts. and numerous ather things and the damned noise is still there. It increases when accelerating and turning to the right, it stops when not accelerating. I took it a work shop and told me that now I need new wheels and Shocks. That these is the cause of the noise. I am really running out of options , money and patience. Actually I thought of turning up the volume and forgetting about the entire thing and waiting for something to come off , but this car belonged to my grand father and he really liked it ( so do I Really ) and intend to bring it back to new condition , but still need to do the 60 K service....And getting a little desperate. LR Work shop ( called the house of terror in Mexico ) originaly told me it was the transfer case .... I have checked it and to my knowledge it is all good No sounds Leaks or anything. Perhaps I should do a check List of everything I need to do acording to priorities right ? What would guys consider as a priority ? Noise , 60 K service , Wheels , Shocks ? Jack up that wheel and see if there is any abnormal play. |
I'm with Mike. I bet it's the CV joints, driveshaft u-joints, or centering ball issue. DAMHIK! JF
Changed the wheel Hubs with ABS sensor Nothing Only No more 3 amigos so far (I bougt these Used on e bay .)
Havent checked CV Joints. Called Shop and told me that IT hadnt occured to them. They are checking as we speak... 5 minutes. http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123 |
Checking Centering Ball and CV joint.. is not as easy as I thought ... will get back to You in 2-3 hours.
