Upper Radiator Hose - tired of changing
After got tired of dealing with thee Plastic bleed screw I decided to replace them with Home depot hardware. see the picture.
I have seen similar works with some sort of Brass bleeder.
Does anyone have an instruction how to do that and measurements?
Also do you have to buy all 3 hoses? can you order the top piece only that goes to Radiator only?
Thanks
Thanks
Man, the way you tightens those hose down will make them burst pretty soon, the connection ends appear too small for at least two of them, and clamps are squeezing hoses far too much,
If you need the longer hose to radiator, then yes you need to buy all 3, but if you need any of other 2 you can buy any 90* bent hose that inside diameter is 1.33" =34mm and long enough,
You are correct. They look funny. I think I used short threaded pipes as extension. Its been a while. these are what I used. I think I am going to redo. The challenges is to out the bleeder.
Anyone have instructions?
Thanks
I avoid worm gear clamps because they are not under tension by themselves. If the diameter of the material it is holding changes/reduced the tension is no longer applied.
Whereas the true tensioners are designed to exert tension within a range of diameters so even if the diameter of the hose shrinks, it still exerts tension.
Only time I would use worm gear type clamp is when it is incredibly major PiTA to place the tensioner.
Land Rover and Range Rover Picture by LR03NJ | 6815514 | LandRoverForums
There is one also at ebay made with aluminum with the bleed screw
Land Rover Discovery 2 Coolant Hose "T" connector
Thanks
Thanks
do you have the instruction and parts needed for it?
I use a similar home depot part and the ends wont be tapered as the NPT style pipe ends.
