Upper Radiator Hose - tired of changing
Post #33 has all you need. I have done this a few weeks back and I wish I had done this 16 years ago.
Hasn't seen over 188 yet.
A copper T-fitting has worked really well for me. I have a thick rubber washer on the bolt head on the inside. I did thread the copper hole for what it was worth. Notched the end of the bolt so I could keep it from rotating when tightening the butterfly nut. Flared the ends out so the hose wouldn't be able to pop off under pressure.
You can also get the brass needle valve LFA-41 drill and tap it on the top of the Tee. Then solder.
DonRW2007
07-02-2015 12:16 PM
sayeedA
03-06-2014 07:15 PM
bcolins
01-06-2014 05:42 PM
bcolins
12-11-2013 01:26 PM
