Used - Rustproof - undercoat?
on my 2003 Disco, the black paint/undercoating is starting to dot rust, its not noticable from more then 3 feet away, but there, is there any soulution to this without spending loads of money? thanks.
RE: Used - Rustproof - undercoat?
If it is the undercoating then you cant see it unless you are under the trk right?
correct, its just on the frame, and under parts.
I wouldnt worry about it. But if it bugs you you could scrap it and re-apply undercoating.
Spray can it black with tremclad rust paint, let it dry for a few days, then go get sprayed with undercoating.
