"UZI" Air compressor sound....
So every 11-12 seconds (by my count) there is an air compressor "uzi" sound coming from my engine that lasts for a second each time. At first my reaction was to check the air compressor for the SLS air suspension in the rear...no sound coming from there.
I have no secondary air SAI on the truck, so what could be possible culprits? |
A/C compressor cycling on and off due to low refrigerant maybe?
Thanks...Thats a possibility... Have not ran the AC in 6 months or so...
Any ideas on how to check the refrigerant level. I will search, but will more than likely go to the shop for this one. |
2 Attachment(s)
You need gauges. You can watch AC compressor clutch. Or just turn off and see if it stops the cycle. One trip to the dealer for this will pay for a set of gauges.
SLS compressor and valves are not as noisy, but here's pix of them just in case. Disconnect C0811 for testing, kills pump and three valves. |
