V288/FV308 PCV Install (Best4x4 Mod)
Old 06-02-2019, 06:30 PM
Landy-04's Avatar
I didn’t drill it out completely I just cleaned it all up but yes drill it out, your truck will love that mod! “Best 4x4”
  #62
Old 06-02-2019, 08:41 PM
Dherna's Avatar
Drilled out
Remains of what used to be the oil separator.
  #63
Old 06-03-2019, 06:44 PM
Dherna's Avatar
Done... end result.
All out...
Drilled out...
Finished... thank you all for your help!!!!! You all are rockstars.
  #64
Old 06-03-2019, 07:02 PM
Dherna's Avatar
Thanks all for the help, you all are rockstars!!!!!!
Stuff out...
Drilled out...
Finished
Oreilly's PCV 308
  #65
Old 07-02-2019, 10:08 PM
huggi's Avatar
Just did this today, have an 03 pulled the little metal tube thing out with some vice grips.....the oil separator was all clogged up. Thanks for the great mod
Best4x4 (07-02-2019)
  #66
Old 08-14-2019, 11:38 PM
Received 1,131 Likes on 781 Posts
Finally got that little booger out, I bought a set of mini vice grips they worked great. It was completely clogged - literally a few pictures for those who are not sure why this is a good idea.
Crud that came out as I got the the plastic Spiral out
State if the spiral, the solid looking bit is the top
After cleaning
The following 2 users liked this post by Richard Gallant:
Best4x4 (05-24-2020), jastutte (08-15-2019)
  #67
Old 08-16-2019, 09:10 AM
Nice work Richard. That is my next task, along with new ignition wires on my 00 D2. First time towing, I had to get a new converter box and 4-pin that attaches to the original box.
Great to know someone else in BC. I'm from Campbell River.
  #68
Old 08-16-2019, 10:04 AM
@JoJo The Giraffe There are a few of us up here, ACG currently heading for Tukin his 03. You should check out the Roverlanders of BC, they are a good bunch. I was over last year bouncing around the North end, Holberg Port Alice etc.
  #69
Old 08-19-2019, 09:44 PM
Bumble's Avatar
Just had a brutal time getting the oil separator out of my 02. It was pretty gunked up, broke off a couple of rings before I was able to yank it out (top nipple was gone when i removed the hose).
So, am I understanding this correctly that it basically decreases pressure in the engine, which should make the valve cover gaskets less....seepy? Is that the net-net of this mod?
Thanks for the helpful info!
  #70
Old 08-20-2019, 12:28 AM
@Bumble More or less the idea of the breather is to prevent over pressure the Rover design lends itself to clogging causing over pressure. This mod removes the separator and small air hole,with a large airway and common PCV restrictor that keps normal pressure. With the added bonus of the change of location making clogging highly unlikey
Quick Reply: V288/FV308 PCV Install (Best4x4 Mod)
