..:: The Vaccum Situation ::..
Hello Roverers,
What should be the reason why after driving a while, and arriving at my destination, I hear the "vaccum" go on for a brief moment, then off again?
What should I need to look at to correct it, if it is a problem to correct ...I've noticed it being done a handful of times, I think.
Thank you all! ;-]#
Thank you all! ;-]#
Hello Roverers,
Thank you all! ;-]#
Thank you all! ;-]#
What you are more likely hearing is the rear air suspension compressor running. Due to the SLS the truck corrects the level when you stop and leave the truck and again when you use the remote to re-enter the truck. This is quite normal and not a problem, that's assuming you have rear air suspension and SLS.
