..:: The Vaccum Situation ::..
SAI = will run at first startup for up to several minutes. 100% normal and the sound generated has a lot to do with the condition of the pump, the filter, the 3 rubber bushings, and the hose connecting it to the rest of the SAI system.
Put your vehicle specs in your Signature. Makes it instant on what you've got vs having to pull up your profile.
I've had similar situation lately too (03 SE) where the SAI will startup for 2-4 seconds after the car is warm, always at idle (stop light or something). It's only happened twice, not a big deal just wondering if its a symptom of a larger problem....as the SAI pump should only come on cold start.
I mistakenly call it a "Vaccum" 'cause it sounds like a "Vacuum Cleaner", but I guess you're right and it is an "Air Pump".
As per "the signature situation", if you are reading this via the "mobile site" on a smartphone, it does not appear for reasons I do not know; but again, my truck's info is there and I see it when viewing as "full site", but thanks for the heads up.
...and why would that be? ...in my case I live in SoFla and it has come on during this winter, now that you memtion it, although not cold at all down here. It did it this morning after a 30 min drive, and outside temp was around 60s, it is a cold weekend SoFla style. ;-]#
The ECM checks the engine coolant temperature when the engine is started in addition to the elapsed time since the
engine was last started. The engine coolant temperature must be below 55°C (131°F) for the SAI pump to run.
NOTE: The ambient air temperature must also be above 8°C (46°F) for the SAI pump to run.
Also, depending on the long term 'modelled' ambient temperature determined by the ECM, the minimum elapsed time
required since the last engine start can be up to 8.25 hours. The period of time that the SAI pump runs for depends
on the starting temperature of the engine and varies from approximately 96 seconds at 8°C (46°F) to 30 seconds at
55°C (131°F).
55°C (131°F).
