-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   valve cover gasket (https://landroverforums.com/forum/discovery-ii-18/valve-cover-gasket-17532/)
wesley64 Nov 28, 2008 09:48 PM
valve cover gasket
just a quick question.could someone tell me the size of the 12 point socket for the valve cover bolts?i would like to pick one up tonight.
thanks
brett 2004 discovery se7
jkid Nov 28, 2008 10:11 PM
RE: valve cover gasket
8mm. The inside bolts are a bit ofa tight fit, so get a 1/4' socket if you can, but a 3/8' socket will do.
Disco Mike Nov 29, 2008 09:23 AM
Factory torque specs were only 6 ft/pounds, so tighten them to around 12 so they won't vibrate loose.
igriego Nov 29, 2008 09:58 AM
My valve cover gaskets are leaking how hard is it to change has anybody done this before. thank you for your inputs.
Disco Mike Nov 29, 2008 10:17 AM
Don't change them, tighten the bolts on the v/c's even if you can only do the 2 outside bolts, then power scrub your engine so it is nice and clean. You should find tighten them snug, not over tightened and the leaking should stop.
To replace them require you yo remove the intake manifold.
jkid Nov 29, 2008 10:51 AM
ORIGINAL: Disco Mike
I put a dap a blue locktite on my inside bolts since they're so hard to get to.
Spike555 Nov 29, 2008 05:53 PM
I just tightened mine, only the two outside ones, leaking stopped. Just snugged with a 3/8" socket and a 6" extenstion.
