Valve Sticking??
Valve Sticking??
Well, just got back from the Rover Indy and he said that all cylinders are getting perfect compression but the #5 cylinder is putting a little bit of oil on the plug causing a misfire. He said it could be a valve sticking. Can this be fixed without a rebuild? Will the ATF "oil" change clear this up?
RE: Valve Sticking??
Can you share the Disco's age and mileage and how much oil do you add between changes, etc. does it smoke at startup for few seconds, etc.
A temporary quick fix that may work will be a spark plug with a higher heat range,but this may cause pre-ignition in the specific cylinder. That is if the existing spark plug is oily when you take it out.
Oil deposits could be caused by your valve seals also, specially on the intake valve side ( oil gets drawn in during intake coz of the negative pressure ). One tell tale sign of this is when you do a valve job, pay attention to the deposit on the intake valve ( larger in dia vs. exhaust valve ). More often than not, the deposit is on the intake valve. Given the mileage on the engine if you haven't had a valve job yet.....
Misfires could be from alot of things, old plugs, faulty plug wires ( cracked, high resistance, shorting ) coolant leaking into cylinder, bad fuel etc. Need more info like diagnostic codes, etc.
Ed
Ed
