Valve Sticking??
on
RE: Valve Sticking??
ORIGINAL: sdsilvere38
Well, just got back from the Rover Indy and he said that all cylinders are getting perfect compression but the #5 cylinder is putting a little bit of oil on the plug causing a misfire. He said it could be a valve sticking. Can this be fixed without a rebuild? Will the ATF "oil" change clear this up?
Has a leak down test been performed?
Don't do anything to the engine till we can get more information.
I would also suggest you send me your tele number so we can get more specific.
