VW G12 coolant made by Pentosin
so i bought some G12 coolant today from the VW dealership to put into the D2 while i get around to replacing the water pump. got some prestone coolant flush at walmart as well. haven't drained the coolant yet, but plan to use the flush to clean out the Supertech 50/50 that's in the D2 now.
I then stumbled across this online tonight.
Pentosin - Antifreeze
look at the bottle on the right of the page with the red top G12
(says Land Rover Freelander, discovery, and defender 1998 and up)
so i should be good to use the 1 gallon bottle of G12 i purchased at VW today in my1999 D2 correct?
i already use this stuff in my 2000 Jetta, so would be great to stock just one type of coolant is all.
JUKE179r (11-19-2016)
Pentosin makes manufacture spec products, so most likely the one you referring to is similar to dexcool, even though it's what Land Rover calls for most ppl avoid it because it forms crystals if there is any air pockets in cooling system due to occasional leaks, use regular green coolant,
that's what most of us use instead on Land Rover spec dexcool.
Im not sure really if this is an actual result of DexCool or just needed regular maintenance. Check the link below some images
Dexcool Pictures
Actually, if you search for the best coolant, Dex cool is within top 3. But if you are looking for the best coolant there are coolants that
can lower your temperature 10 to 15 degrees. These are more expensive alternative. I would like to try them but my disco leaks all the
time. It use to leak so bad that I have gallons of antifreeze on my roof rack. But not anymore, I settled with just drops. Cheers!
Dexcool Pictures
