-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Want to replace that ugle brake boot? (https://landroverforums.com/forum/discovery-ii-18/want-replace-ugle-brake-boot-49852/)
FlyingZebra34 May 19, 2012 12:26 AM
Well it is very simple if you want to sew.
You will need some fabric that you will like and will function in the vehicle without getting snagged or anything. So materials like leather are to thick. denim like materials work best but what ever suits you is fine. (don't use anything thin or else you will have problems later). You will also need some epoxy or crazy glue (I prefer epoxy), thread and needle, some pins, and some paper clips.
First off remove the ugly brake boot. There is a rubber ring holding it to the handle itself, be careful not to break it, mine had some play to it but I don't know where to find a new ring if you do break it. Maybe a hair tie?
http://img33.imageshack.us/img33/9725/img0111ra.jpg
Once off you will have this thing
http://img404.imageshack.us/img404/5764/img0237ov.jpg
There is only one part that actually is stitched together and it goes from the handle to the base and you can take it apart with a knife or thread puller. You will also have to pull the glue they used apart, don't worry if you tear anything, you just need the basic shape of it. Once apart it will look like this.
http://img151.imageshack.us/img151/7650/img0239sp.jpg
Now, using your new material and some pins to hold down the old material, make a new piece of fabric to use for the boot.
http://img545.imageshack.us/img545/1231/img0253ttc.jpg
After tacking it down, cut it out. You should have something very similar to this.
http://img593.imageshack.us/img593/2723/img0256dd.jpg
Feel free to clean the edges if you want but most of them will be hidden so I wouldn't worry about it too much. Now remember how the basic shape of the boot was put together and go ahead and stitch the front seam together first.
http://img52.imageshack.us/img52/3568/img0257ai.jpg
After that line up the little wire frame and go ahead and mix some epoxy
http://img41.imageshack.us/img41/927/img0258nv.jpg
Now you will be gluing all the edges together to hold the fabric around the wire frame. Be careful not to use to much, as it will soak the material and be chunky, but not such a little amount that makes terrible surface contact. (maybe try practicing on some scrap material to see how it reacts?)
http://img593.imageshack.us/img593/2541/img0259uv.jpg
Now after gluing things together, use paper clips to hold things together while it is setting.
http://img341.imageshack.us/img341/603/img0260qr.jpg
Now you can clean everything up and go ahead and reinstall.
This is what I got -
http://img543.imageshack.us/img543/6286/img0263hx.jpg
http://img98.imageshack.us/img98/7551/img0264n.jpg
Now I hope that everyone can follow my crude instructions but personally, I was so tired of that piece of junk flaking everywhere that I was willing to try anything. This is pretty easy is you have ever done some arts and crafts. Overall I probably spent about $15 and about 2 hours worth of my time getting materials do doing the work plus 30 minutes to dry the epoxy. Overall I'm happy with it and I hope it works for anyone else who tries it.
Disco Mike May 19, 2012 09:01 AM
I got lazy and just ordered a replacement, that being said your's is a great idea especially if you want to use some different type of material.
buick215 May 19, 2012 04:28 PM
What I like even more are the two screws holding the center console switch panel together. ;)
wilson96rr May 19, 2012 06:02 PM
there is a guy on ebay who sells the replacement boot for the brake and shifter pretty cheap
FlyingZebra34 May 20, 2012 03:13 PM
Ah, I guess I didn't see it. All I could find was the original replacement that costs like $80 or something. I thought that was crazy and just decided to make my own.
vandev May 20, 2012 04:25 PM
Here you go..
LAND ROVER DISCOVERY 200 300 TDI TD5 V8 SET GREEN ST | eBay
threalassmikeg May 22, 2012 06:17 AM
1 Attachment(s)
Nice work!!
Micro suede is nice to work with.
Attachment 43147
petminded Jan 23, 2016 09:35 PM
Dear Moderator,
Some of the pics no longer work for this post. Can this be resolved or can someone make a new 'how to' post?
Alex_M Jan 24, 2016 11:25 AM
The images are hosted externally so the original poster would have to re-upload and re-link the images. As for someone else doing a write up, well, that's up to anyone else willing. Should be simple though, I'd say you could follow along without pictures.
cappedup Jan 24, 2016 12:19 PM
Originally Posted by petminded (Post 551120)
Dear Moderator,
One of the first jobs I did is remake mine out of thin leather.
https://landroverforums.com/forum/discovery-ii-18/swap-ratty-old-handbrake-gator-nice-leather-one-69341/
Pics still work ;)
