Water Crossing
Water Crossing
Outfitting my 2000 Disco II with a snorkel. The only snorkel I have been able to find is the ARB Safari. I'm sure I have seen others that connect to the fender without the elongated tube running parallel to the fender top. Any other good snorkel manufacturers out there?
Also, is there anything else I need to do to my motor to make it safe for a river crossing? I have read somewhere in this forum that if you powerblast your engine after a day of 4wheeling, to cover the alternator beforehand. If I have to cover the alternator, then how the heck will it hold up if its underwater?
Anyone know what type of bumper this is on the grey Disco pictured?
For a single water crossing, just go through and make sure the water doesn't go above the headlights and you're in the clear. If you plan on doing it a lot consider extending your axle breathers and as you said getting a snorkel. You don't need to cover the alternator. These trucks can handle some pretty deep water without any mods at all.
I believe the bumper in question may be a Safari-gard bumper. Even if it's not, if you like that one you'll like theirs!
http://www.safarigard.com/store/index.php?cPath=35_26
on
Check this site for that bumper also, if the one you saw was a Safari Guard and you like the style, consider the RTE because it is a whole lot stronger.
How deep are you planning on going? It will take more then a snorkel to keep the water out of your truck and it's electronics.
How much of a lift do you have and what size tires?
http://www.rovertym.com/
