Water pump removal and having issues....Please help.
I am removing the water pump and have been trying to remove the fan clutch all afternoon, to no avail. I cannot seem to loosen the nut from the pulley shaft.
Any tricks? I even made a tool that fits over the bolt heads of the pulley to keep it in place while reefing on the clutch nut....I am dead.
Any help would be greatly appreciated.
Thanks, Shaun
Thanks, Shaun
Mine wouldn't budge either with a large crescent without turning the pulley. Bought one of these at harbor freight and locked it around the pulley. It came off with the first hit of the crescent.
Locking Chain Clamp
Locking Chain Clamp
Lisle LI43300 Pneumatic Fan Clutch Wrench : Amazon.com : Automotive
Makes the job a 5 second affair...
I had a hell of a time removing mine. You know why? Some idiot thread locked the fan clutch to the water pump. I ended up removing the whole water pump, and ordered a new fan because I was already going to replace the fan clutch. I whacked and whacked and whacked that thing before finally giving up and taking the whole pump off, which is a BEAR to do with the fan in the way.
