Water temp and Oil pressure gauges
So i finally installed my Oil pressure and Water temp gauges. The first pic is with them installed but not hooked up to the sensors.
This is with the sensor hooked up and this is the idle oil pressure:
This is the max pressure at WOT:
Sandwich adapter with MANN filter:
I haven't installed the Water temp sensor yet but when i do ill update the thread.
I'd swap positions, so the most critical, temp, is lower so you don't have to take your eyes off the road as far to read it.
Just an FYI on the filter. From what I can find online MANN has a poor design, the bypass valve is in the dome end, so if it goes in to bypass mode the oil going to the engine is passing over all the crud in the bottom.
