-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Weird Problem (https://landroverforums.com/forum/discovery-ii-18/weird-problem-22748/)
SJRover Jun 15, 2009 05:26 PM
Weird Problem
Just hit 90K miles on my O1 LR Discovery Series II SE- here is what i'm experiencing:
1. front side passenger seat belt all of the sudden stuck and can't be pulled for passengers to buckle up- how do you fix this???
2. passenger side window gets stuck if rolled down to bottom
3. engine is making funny tat noises almost as if something was in the fan
4. lots of loose clanking of front side moonroof when opened and going over bumpy roads
Help!
Disco Mike Jun 15, 2009 05:37 PM
Stop using any of those items and send me your tele phone number, I'll call and walk you thru this.
Spike555 Jun 15, 2009 07:50 PM
1-remove the cover off the seatbelt winding thingy on the floor, there is a latch in there that is stuck.
2-you need a new window regulator, or fix yours buy replcing the broken wheels.
3-open the hood and look for the fan hitting something, with the engine off spin the fan by hand.
4-your sunroof track is worn out, close sunroof and dont worry about it or replace the track.
www.roverlandparts.com
Night Train Jun 15, 2009 10:19 PM
Help!
1. place passengers on the hood with a ratchet strap
2. do not roll window to the bottom
3. threaten engine to make serious noises instead of funny ones
4. apply tight to remove the loose and never ever drive on a bumpy road
these may not work for everyone but, they are economical!
Spot On
