Went to auto zone and got some error codes??
I got three error codes.. p0150
p1174 and p0174
One says oxygen sensor 1 in bank 2
second says cam sensor fault
and the third says that fuel system for bank 2 was too lean..
Ok so any help on these reads would be much appreciated!!
I am most concerned with the one that says cam sensor fault!?
Thanks in advance!
p1174 and p0174
Thanks in advance!
on
RE: Went to auto zone and got some error codes??
At this point don't worry about the 1174 fault, get your 02 sensers orderd and replaced, then go have the codes read and cleared, you should be fine then and I bet the 1174 will go away.
As for when to replace the 02's, usually before 100,000 depending on the type of driving you do and the fuel used. It is not unusual to see 02 faults showing up in the 80,000 range.
