Went to auto zone and got some error codes??
Old 10-17-2007, 04:02 PM
okdiscoguy's Avatar
Default RE: Went to auto zone and got some error codes??
You said the second code stated a cam sensor fault. I was saying that the 1174 was not a cam sensor fault. The o2's have heaters in them and the 1174 is a heater error. (I might be wrong). But it is not a cam error.
Using Seafoam wouldn't hurt anything, but you would get more benefit out of doing a throttle body cleaning..
Old 10-18-2007, 04:06 AM
hollis's Avatar
cool thanks!! any other product out there besides the deep creep?? I cannot find it..
Old 10-26-2007, 11:45 AM
hollis's Avatar
ok so i changed the 02 sensors and the check engine light is on. do i need to go to a dealer to get the codes turned off or is there another way? remove the battery cable?
Old 10-26-2007, 01:50 PM
hollis's Avatar
ok so I just got off the phone with the dealer and they gave me an estimate of $345 to clear the codes?! He said it takes 2-3 hours?? Does this sound right? Should the SES light go off after I changed the 02 sensors?
Old 10-26-2007, 02:04 PM
Jawbox's Avatar
If all they plan on doing is clearing the codes, then it is much cheaper and easier to clear them yourself. If they intend on doing diagnostic work beyond that, then it may be reasonable.
Put it this way, if you just want to clear the codes, you can go to Autozone, buy an ODBII scanner for $100 or less, and clear them in less than a minute with the tool.
Old 10-26-2007, 02:19 PM
hollis's Avatar
I saw on here that an ODBII does not clear a service engine soon light...?
Old 10-26-2007, 02:56 PM
ORIGINAL: hollis
Cool thanks!! sorry to steal my own thread but... any benefit of using seafoam again.. ?
NO!!!!!!
Old 10-26-2007, 02:58 PM
ORIGINAL: hollis
Call me as soon as you get this and I will make this all clear for you.
303-872-7680
Colorado 7 am to 8 pm
Old 10-26-2007, 02:59 PM
ORIGINAL: hollis
You're getting things confused, call me.
Old 02-15-2008, 11:52 AM
qwerty589's Avatar
Just for the record, I also have the P1174 fault code coming up. It came shortly after I was filling up with regular gas. My wife put some premium in and the check engine light went out soon after that. It has since come on again.
It's looking like it's an oxygen problem but I'm just speculating.
Thanks for the forum, new to LRs.
2003 Disco.
Quick Reply: Went to auto zone and got some error codes??
