what am i missing here?
just bought an 04 D2 S and had a quick question, what am i missing on my fuel door? I think that I need a new actuator because I don't hear anything when I push the button but haven't checked any fuses or anything however I know that something just seems like it's missing back there. I know that these pics are not the clearest but hopefully someone can identify what if anything I need to buy.
What do you have to do to open the door currently?
fuel door
did my pictures not show up? There's a metal pin that's about 2mm around that sticks out about 5mm, I assume that there is supposed to be a piece that fits of the metal.
Right now the door is just open, it won't close/latch because that pin sticks out and hits the part on the door that I think it there to catch the door and keep it closed. I'll try to take better pictures tomorrow.
I think you are missing this part. I had to replace mine too
Fuel door latch
http://www.roverparts.com/Parts/BPX700010G.cfm
Fuel door latch
Fuel door latch
Fuel door latch
Bump -
I have a similar problem.
1) Does the plastic piece you mention fit on the door to the fuel tank? or does it fit inside the metal where the pin actuator is?
2) My problem is that ours broke and the door kept coming open. I bent the latch of the foot (the peice of metal with the hole in it) closer to the pin and the pin was going in and out and was locking the fuel tank door. That was good for a few weeks, now the pin itself want back into its hole and will not come out.
3) I know the pin actuator is still working. When I hit the dash button I hear the clunk clunk of the pin going in and out, but the whole actuator (this is what I think the piece the pin goes in and out of which is housed inside the hole) must have somehow been moved towards the rear of the car, thereby preventing the pin from coming out.
4) I need to find out how to get to the actuator, which I guess I have to remove the entire interior back passenger side (US car) plastic to get access to this piece, but it sure seems like a very difficlt endevour.
If anyone can give any help I would appreciate it. Maybe someone has had the same problem with the pin not coming out of the hole and can give me a tip on how to coax the pin through the hole.
Could someone could point me to a photo that shows how the replacement piece above fits onto the door. I mean this is anenormous piece for such a small door, I can't even begin to fathom how the piece pictured would even have the room to fit there.
Could someone give me a pointer to any utube about how to take off that interior trim that conceals the interior of the rear passenger near where the gas tank actuator sits?
Please advise. Thanks!
