Old 01-13-2018, 01:14 PM
Fastercat's Avatar
Had to test the cdl lol.
Parts galoreIt’s been a busy couple weeks, I brought home 2 more parts trucks, fixed a coolant leak with a REAL hose clamp, got muddy, and even test drove an lr4. Gotta love the power from that jaguar 5L.
  #4812
Old 01-13-2018, 05:00 PM
Alex_M's Avatar
Those are still smaller than 265/65r18s which I ran at sock height with no rubbing. They'll work perfectly.
Originally Posted by Sandman614
Working on getting this thing ready to pass inspection (10day temp tag). I ordered D1 wiper arms, new windshield sprayers, and need tires. I know a guy wanting to get rid of a set of 265/70/16, they don't seem much bigger than the stock 16s and i've searched and found that a 245/75/16 "is the biggest I can fit stock". There doesn't seem to be much of a difference there too.
255/65/16 vs 265/70/16
245/75/16 vs 265/70/16
  #4813
Old 01-13-2018, 05:28 PM
The Deputy's Avatar
Received 1,160 Likes on 836 Posts
Looking good. You're about ready for a wheeling adventure.
Brian.
  #4814
Old 01-14-2018, 05:48 PM
Friday Night Disco's Avatar
Took Tricky Dick up to the mountains today!
Wish I could track down another Disco owner in my neck of the woods that likes rolling the back country. I turned around when I got to an area that I didn't feel comfortable trying without a spotter/recovery rig (50 point turn for the win)
The Deputy (01-16-2018)
  #4815
Old 01-14-2018, 11:42 PM
c0smic's Avatar
4wd High
Did some maintenance on the disco today. Got some Gunk Multi-Surface cleaner and hit pretty much every greasy, oily surface under the car. It was surprisingly effective! I just got this disco recently so it's good to set a base line for how everything looks going forward. Now I'm pretty sure my rear main seal is leaking, there's drops of oil coming down between the engine and tranny bell housing. That'll be a fun job...
After cleaning up the underside, I changed the tranny fluid and filter. The ATF was surprisingly clean, so it probably didn't need to be changed but I'm glad I did it anyway. Went with Valvoline Max Life.
And I got started on flushing my coolant. The car has been running on the hot side (gets up to ~210) and I'm pretty sure there was air in the system and it wasn't totally full. Had the 'waterfall' sound sometimes. Decided to go with Zerex G-05. Also replaced the thermostat with the 180 version from lucky 8.
back-flushing the heater core
ATF goin in
Valve body
  #4816
Old 01-15-2018, 12:59 PM
Greg Vasileff's Avatar
04 shifter on my 01 which came with CDL. So cool to see that dash light. The only dash light that has brought a smile to my face
  #4817
Old 01-16-2018, 05:04 PM
Alex_M's Avatar
Got my first ever CB radio installed today! Got some kinks to line out, but pretty happy overall.
  #4818
Old 01-16-2018, 05:24 PM
Don't let the kids listen. LOL Some crazy sick crap on there.
  #4819
Old 01-16-2018, 05:31 PM
Alex_M's Avatar
Haha, no kids to speak of yet. Just coming up on 22, myself; still a bit of a kid.
Not hearing much on it yet unless someone is pretty close. Gonna swap out this cheapy antenna for a Firestik and I need to ground the mount better. I'm honestly not sure yet if its grounded at all...
  #4820
Old 01-16-2018, 05:39 PM
Jeff Blake's Avatar
Alex, I think that's the oldest part on your disco now.
You can pick up a cheap SWR meter on amazon to tune and test.
There are NGP firestik antennas (no ground plane), but honestly the best way to do it I found (after tons of research), is to get a standard 3/4" NMO mount with a Larsen whip antenna (https://www.dxengineering.com/parts/lsn-nmo27b)
The firestik was too thick and rigid, no way it could have survived in the bush.
Drill the roof, and you'll have the best ground plane possible. Anywhere else is second class. Since I have a roof rack, I opted to get a z-bracket and attach it to the side of the rack. There's a picture on here somewhere.
And if you ever want to change to HAM or another type of radio, the NMO mount is pretty universal, just swap in a new antenna.
Quick Reply: What did you do with your DII today?
