Kinda like the DI side, but include what you did to it AND with it.
Yesterday - PULLED Tree out of pool that hurricanr put there. Tonight - Changed transmission fluid and filter in my 03 also changed power steering fluid. Tomorrow - Front U joints and center ball Tip: autozone doesn't carry filter for 03 dii but ask about a say 98 D1 and they'll have it, exact same part. |
To be honest, I haven't done anything than normal maintenance for awhile! It's a solid work horse!
Haven't moved mine on over week since I broke a motor mount and the fan exploded. (The fan took out the radiator, upper shroud, coolant return line, air box, and parts of the fan tried to punch up through the hood.). Then the shaft on the PAS pump decided to walk out about 4mm and shreaded the belt, so...
...in the last week I've done the following: - Replace the radiator, fan, fan clutch, cooling return hose. - Flushed and bled the cooling system. - Replaced 2 motor mounts. - Made a custom, 5-rib belt to get the truck home when it tried to slice 2 ribs off the existing belt. (All I did was trim the rest of the 2 ribs off, but I did it on the side of the road in the middle of the night!) - Pulled and replaced the PAS pump with a brand new one. Today, - I'm re-bleeding the cooling system (temps just weren't stable enough for my liking before the fiasco with the PAS). - Bleeding the PAS pump. - Maybe (time permitting) replacing the rear drive shaft with a u-joint rear drive shaft. (I'm just tired of wasting $$$ on rotoflex couplers.) |
Originally Posted by dcarr1971
(Post 341216)
...in the last week I've done the following: - Replace the radiator, fan, fan clutch, cooling return hose. - Flushed and bled the cooling system. - Replaced 2 motor mounts. - Made a custom, 5-rib belt to get the truck home when it tried to slice 2 ribs off the existing belt. (All I did was trim the rest of the 2 ribs off, but I did it on the side of the road in the middle of the night!) - Pulled and replaced the PAS pump with a brand new one. Today, - I'm re-bleeding the cooling system (temps just weren't stable enough for my liking before the fiasco with the PAS). - Bleeding the PAS pump. - Maybe (time permitting) replacing the rear drive shaft with a u-joint rear drive shaft. (I'm just tired of wasting $$$ on rotoflex couplers.) And im trying to get the title fixed :D |
Originally Posted by Rover De Land
(Post 341219)
Dang that sounds bad...
Damn Dave that sucks.
Spencer, good luck with that title! I finally had to change my throttle body heater plate and gasket. |
Watched it sit outside work as I drove my new motorcycle :)
Gave my truck a wash and detail. Going to do it again pretty soon. Just wanted to get it clean and get some wax on it since it has been sitting so long. The roof rack looks a lot better with the lights painted black, still looking to get a lower profile for them though.
Before... http://s18.postimage.org/g286rvnwp/DSCN3038.jpg After http://s18.postimage.org/5cuhzmc3t/DSCN3055.jpg http://s18.postimage.org/fufyhmnk9/DSCN3051.jpg http://s18.postimage.org/ozobbhqyx/DSCN3050.jpg http://s18.postimage.org/f13cp0hjd/DSCN3046.jpg http://s12.postimage.org/t658zwm4t/DSCN3056.jpg http://s12.postimage.org/t7f6tbnyl/DSCN3061.jpg |
Originally Posted by lr2001silver
(Post 341225)
Damn Dave that sucks...
Forgot one other thing on the list today. I have to drop the tank skid and run it down to a local fab shop to add a 45* bend to better cover the back of by tank. After adding my new bumpers it's a little exposed, and I don't want the skid to act like a shovel if I have to reverse over something... https://lh4.googleusercontent.com/-9...20706-1238.jpg |
Nice detailing!
Ill paint my fender flares once I'm sure it won't rain.. Water is still rising here our interstate and main highway strboth underwater so I had a little fun with that. On my way to get last u joint.. |
