#3101
#3102
If you need to know what the code is, should be a P0304. The last number goes with the cylinder. P0305=5, P0308=8, etc. Or did you mean chase down the cause? The list is usually check plug, wire cap secure, wire bad, ignition coil dirty, faulty (usually not just one terminal goes bad), clogged/messed up fuel injector, air leak past the MAF, etc.
Tennessee Disco (02-03-2016)
#3103
Installed Terrafirma medium duty lift kit and steering damper. It's awesome!
Didn't have to disconnect sway bars at all so bonus!
Got many inches out of it because I had lost 2 inches in the factory springs here at 170k miles. That, paired with the 2 inch clearance I got from moving up to 33" BFG AT T/A KO2 tires gave me a solid 6" lift from where I was before. Awesome!! Bring on snowmageddon!
Luckily I still have 2 more inches clearance in my garage door after lifting! Hmm, if I get steel bumpers now, I bet I could get another inch for garage clearance, and then I could get a low profile rack on the front half of the roofline... And then a winch... And the cargo storage drawers...and a dual battery...and an air compressor...and..and...
#3104
So I made it back to Fairbanks (will be heading back down to Washington later this month, would up with a place outside Bellingham).
The Disco was rock solid all the way from Haines to here, except that the windscreen fluid FROZE at one point along the way ... ... life in the boreal climes ...
Didn't stop to take any pics on the way up; perhaps on the way back down, as I'll be taking the road all the way (I jumped on the ferry from Bellingham, WA to Haines, AK and spent three days aboard it instead of driving) and am going to try and pace the trip a little slower.
Biggs did a great job on tweaking the machine!
#3105
Rock Hard Red Sealant -- Slowed Water Pump R&R
Mid 70s so good afternoon for pump replacement. Used my trusty ramps for better access to block drain plugs and to allow 5 gallon bucket beneath vehicle to catch drained fluids.
This was my 2nd time removing block plugs and re-installation was much easier this time, unless you fear getting dirty just do it. Plugs removed for more complete block flushing and to drain as thoroughly as possible because system refill will be made using 50/50 premix. Upon removal found a significant amount of coolant left in the block, pump inlet hose had been remove but didn't think to remove long pump bolts prior to plugs to see if that would have made a difference.
Once pump removed newly accessible areas degreased/cleaned. Then on to old gasket removal. This may be original pump since no changes are recorded in mx records. Prefer to use non-metallic scrapers particularly on aluminum. Tried heat gun with no joy and will need to resort to the metal ones when resuming tomorrow.
Interestingly found another chunk of old plastic sitting in the by-pass valve port of my week old thermostat after having accomplished several prior flushes.
#3106
#3107
#3108
any pics?
#3110
Love: just saying no to 10w-30. You should be fine but you might want to look at the WM oil specs, particularly the recommendations for non-NAS vehicles. If you start hearing a tapping at idle after warm it will be a hint to use a higher viscosity oil.
