Old 03-10-2017, 01:06 PM
disco203lr's Avatar
wth, I need this in all 3 of my vehicles like yesterday!
Originally Posted by MacRoadie
Something slightly less complex....
  #3762
Old 03-10-2017, 07:51 PM
Jeff Blake's Avatar
Nice move on the USB.
Today i I actually finished a project! Table.
  #3763
Old 03-11-2017, 11:23 PM
JUKE179r's Avatar
I had a loud squeal coming from my 2001 Disco's engine pulleys.
Found it! The plastic belt tensioner pulley had cracked. The bearing was loose and floating around inside of it.
rossagge (03-12-2017)
  #3764
Old 03-12-2017, 08:13 AM
The Deputy's Avatar
Received 1,275 Likes on 896 Posts
Tested tires and front bumper. This slope doesn't look that steep, but the push-up (created by the Dept of Natural Resourses) was flush with the hood and nearly vertial on the approach side.
She walked right up without the bumper even touching. So, I guess she passed.
Jeff...that table turned out awesome...has quite the professional look to it. You could market that very easily.
Brian.
  #3765
Old 03-12-2017, 08:20 AM
jringeno's Avatar
Replaced all 4 rotors and pads with PowerStop cross-drilled/slotted rotors. They work like a champ. My D2 wants to try and stand on its nose on hard braking. Next weekend i get to install my Terrafirma med +2 lift and power steering pump.
  #3766
Old 03-12-2017, 10:53 AM
Twix's Avatar
Added some lighting to Emma. I can finally see in reverse now.
  #3767
Old 03-12-2017, 02:15 PM
Friday Night Disco's Avatar
How did you wire them up (i.e. vampire clips to existing reverse lights, leverage rear fog, tapped into trailer plug)?
  #3768
Old 03-12-2017, 02:22 PM
rossagge's Avatar
Originally Posted by Jeff Blake
...Today i I actually finished a project! Table.
Nice Job!
  #3769
Old 03-12-2017, 02:39 PM
rossagge's Avatar
Cool. Just did a little light job myself.
Just finished installing and wiring up my 50" LED light bar. Mounted it to the rain gutters using some brackets I bought from Smitty Built. Gonna loom up and secure the wiring from the bar down the A pillar when my new trim arrives. Did a wet weather drive/test last night and it seems solid. Also replaced low beams from a pair I got from Rover's North. Suppose to be brighter...
  #3770
Old 03-12-2017, 03:03 PM
zoltan7's Avatar
You can turn that switch side ways, drill out that remaining raised section and run it in perfectly flush right there.
That's exactly what I did with my LED bar switch
Just use a dremel and be careful not to nip off those tabs on the back
Quick Reply: What did you do with your DII today?
