#4031
Put some new rubbers on the panty dropper. I went with a set of street tires for now till I do a lift and all. They are the blacklion bc86 and were exceptionally reasonable ($560 installed with lifetime rotate and balance and road hazard with a 60k warranty). I was skeptical at first but the bands were going bad in my back two tires and it felt like a bed at a cheap hotel that took quarters. I went with a 245/70/r16 and they are surprisingly quite and smooth on the road. I will get the fallen' s at3 wildpeak when I do my lift but did these for the time being. Wife was a whole lot happier with that price too instead of getting an all terrain tire right now and a happy wife makes for a happy life.
#4032
Well damn
Well, damn.
I would just like to submit my humbly correct opinion that super lock is stupid. Period.
Took my 2002 DII to the shop to get the rear bumper replaced after getting rear-ended. Told them NOT to lock the vehicle at all (since I didn't want to get into the specifics of super lock and which lullaby to sing depending on which door super locks). Of course, they super locked the thing and the rear tail door is stuck.
How fun.
First, I took all the normal steps of super lock denial: I lubed the handle (actually, I drowned the handle in WD-40 and PB Blaster); I double clicked the key fob 1000 times; I double unlocked with the key; I tapped (banged) on the door around the actuator; I took old Disco for a bumpy ride along a rocky desert vista and invited vagrants to steal it; I pulled off the door cover inside and actuated all arms and appendages of the actuator manually while politely walloping the actuator section of the door.
Then I accepted the possibility (certainty) of a super lock malfunction and jumped the common and super lock wires. My heart leapt when I thought I heard the mechanism release. Alas, it was my hopeful imagination. My rear tail door is still locked.
I think I will go buy a new air chisel and cutter. If I can cut out this section of door, I'll rebuild it from a low-grade oak and secure the door with a Velcro latch. Hell, I might extract all the lock actuators in favor of Velcro. I'll post a step by step if it works...
Super lock is stupid. You know I'm right.
How fun.
#4033
Well, damn.
How fun.
How fun.
Caleb.hunter (05-25-2017)
#4034
It's good to know I'm not alone. Whether I go with the chisel or high explosives, I'll see about posting video...
#4036
Fixed the broken transmission pan drain plug. Pretty painless with a left hand drill bit.
Drove around, monitoring temps, and checking handling after installing the new radius arms. Feels like the suspension handles wayyy better now, but that could also be due the previously finger-tight front upper shock bolt...
Temps are 204-212. 212 in stop and go, 204-208 when at speed. I'm okay with that for now. Motorad 180. Though I hit 221 starting her up after a gas-up... quickly went back down to 208 though.
#4037
#4038
My turn again...
Added a front runner rack. I like it a lot better than the Baja, because its made of aluminum, has flat bars, and no side rails. Construction is top notch. The one problem I have with it ... it's too short. It should be 6-8" longer. I left a slat out near the front so my sunroof is unobstructed, but it looks a little funny and should be moved back a bit, but the sunroof is too hard to give up. Rear sunroof is no longer usable, but thats ok.
#4039
Replaced my belt tensioner finally. Found out a PO had cross threaded the bolt for the pulley so the threads came out with the bolt. I had put a paper clip in the hole then jammed the bolt in to get me by. Also scanned my abs module because of random amigos riding along. Shuttle valve. So I re wired that. As of right meow, everything works. (Knock on wood)
#4040
Had the alignment checked again after adding the caster corrected arms. I'm still .25% short of the minimum, which is fine... maybe when I add a winch and rock sliders it will drop into spec. I have the TF 3" HD springs/shocks
Since no adjustments were needed, les schwab didn't charge me anything! That surprised me.
