Old 07-31-2017, 05:21 PM
LR03NJ's Avatar
Default Rust removal today
  #4282
Old 08-01-2017, 01:40 PM
Jeff Blake's Avatar
Long overdue car wash. Here's how Reggie stands today
couple more projects and I'm out of ideas
  #4283
Old 08-01-2017, 03:10 PM
The Deputy's Avatar
Received 1,275 Likes on 896 Posts
A nice retractable canopy, with a couple canvas chairs...for some rest in the shade. You deserve that...the rover looks great.
Brian.
  #4284
Old 08-01-2017, 03:53 PM
Luckyjayb's Avatar
Looks great jeff. I added new fender flares today.
  #4285
Old 08-01-2017, 03:54 PM
Luckyjayb's Avatar
Oh and window vent visors and bought the interior from fizzbizz and the 2" lift
  #4286
Old 08-01-2017, 07:21 PM
Jeff Blake's Avatar
Did a DIY breather extension for the diffs, tcase and transmission.
After buying an "onboard air kit" I learned my lesson that a) you won't half the fittings they give you b) you usually get crappy fittings like compression instead of push to connect, etc.
And doing it DIY, you can come up with a better routing method.
The terrafirma or ARB kit is literally just some hose and a few PTC fittings. On to Mcmaster...
That's everything you need. I had some 1/4" p-clips that I used to secure the tcase and trans line to the immobilizer switch.
The tcase and trans line go up the RH side, and go from 6mm to 8mm hose using reducer fittings. Then the 8mm line is routed behind the engine using a couple existing clips to snap into. The line meets up with the diff lines, merges into a single 8mm line, and goes up along the snorkel. Then stick the hose into the snorkel so no water gets in.
  #4287
Old 08-01-2017, 10:40 PM
shady milkman's Avatar
Had to put in new magnecor wires since one off my sti wires (#4) rusted out and was causing misfires and a P0304 code. Left the manifold on and did the entire job in less than three hours. A big improvement since the last time I did it I spent a day and a half. SAI tubing is a real PiTA! It's amazing how much better the rig feels with the new wires.
  #4288
Old 08-02-2017, 06:30 AM
zoltan7's Avatar
Dr Jeff
What mount are you using for your maxtrax's (or clones lol)
I will 100% be extending my breather tubes now thanks to you
  #4289
Old 08-02-2017, 09:50 AM
Jeff Blake's Avatar
Front runner outfitters
  #4290
Old 08-02-2017, 10:06 AM
zoltan7's Avatar
ahh exclusive to the rack likely then
Quick Reply: What did you do with your DII today?
