What Gear Oil should I buy?
I have been running Redline sythetic 75/90w. Is the Mobile 1 syn power good? The local parts store that carried Redline went out of buisness. I could drive into Seattle to buy some if it is better. What weight are you guys running? I want to change the front and rear diffs. and the transfercase this weekend.
Thank you, Willie |
Mobil 1 is good, redline is better. Royal Purple makes good gear oil too. How many miles do you have on the Redline? It should be good for 90,000 miles.
I have 100,000 miles on it. I should have changed it a long time ago.
Willie |
I just filled mine up with Mobil One.
80W 90 Lucas, you can see the difference. I ran mobile on in the front and lucas in the rear to test, the rear oil is MILES better over 1 year. I now use all lucas in all three diffs
I have seen references to using the heavier 75w140? as well, do you use it in all the tc , diff, and swivel balls joints or limit it?
Originally Posted by oljohnboy
(Post 169845)
Originally Posted by Danny Lee 97 Disco
(Post 169854)
1 Attachment(s)
Originally Posted by lipadj46
(Post 169863)
Lucas better than mobil 1, that's funny. Lucas is the bastard stepchild of the lubricants family though their synthetic gear oil is OK. Also Mobile is a city in alabama.
Read this and you can pick your own oil! |
i use lucas synthetic it works great and quiets the gears a little
