-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   What is the red plastic ring/grommet on the intake manifold vacuum line called (https://landroverforums.com/forum/discovery-ii-18/what-red-plastic-ring-grommet-intake-manifold-vacuum-line-called-61824/)
ZGPhoto Sep 17, 2013 09:11 AM
Is ****** really edited out? Wow.. why?
jafir Sep 17, 2013 10:32 AM
Originally Posted by bcolins (Post 421111)
I'm heading to a junk yard today that has some D1s,....will the red grommet from a D1 work? If so, how is it released/removed?
I don't think D1 has this part; I don't think they have a plastic vacuum line to the booster.
jafir Sep 17, 2013 10:33 AM
Originally Posted by drowssap (Post 421114)
you can replace it with a ****** brass fitting from any hardware store and a tap.
b a r b e d brass fitting
I think you are thinking of the other fitting that everyone breaks.
Jpcoldwell1127 Dec 12, 2023 01:14 PM
Originally Posted by bcolins (Post 420626)
Need to order one of the Red circular plastic grommets (for lack of a better term) that goes at the end of the (1/2" diameter?) vacuum line that plugs into the intake manifold near the oil fill neck. Can someone tell me what that is called, and best source for one?
Brian
Part # LR052965 Kit-Intake Plug (go to an OEM manufacturer site and plug in this part number). I paid 9.39 USD
JUKE179r Dec 13, 2023 01:31 AM
I replaced my brake vacuum connector with a Saab part number 55557389 connector for $12. It’s a direct replacement. I use a long extension and went through the intake manifold to push out the old connector.
Externet Dec 13, 2023 10:47 AM
As I did not find its name, replaced it with a named 'red silicone' 12 years ago and has never complained for the christening since. ;) But I believe bubble gum can work there as well.
