What serpentine belt to buy?
So I've been tooling around in my car, and I noticed that my serpentine belt is starting to wear out. It probably won't break on me any time soon, but I figure that its better to be safe than sorry, so I might as well replace it while I'm doing all this other stuff.
So what do I need to get? I have a 2002 Disco II, and I'm not sure if I have "ACE". How can I tell?
RE: What serpentine belt to buy?
www.autozone.com
www.atlanticbritish.com
www.roversnorth.com
www.napaonline.com
Any one of those will give you what you need. Just enter you year, make and model. Doesnt matter if you have ACE or not since that runs off the powersteering pump.
www.roversnorth.com
www.napaonline.com
D2's actually do have two different serp belts. The ACE runs off the belt so there are different lengths to choose from.
http://www.roverparts.com/TechTips/s...routing_D2.cfm
Edit: The way to determine if you have ACE or not is to look at the power steering reservoir. If the tank has two fill caps you have ACE, if there's only one fill cap (with the steering wheel on it) you don't have ACE. I don't have it so I can't say what that cap looks like.
on
ORIGINAL: Spike555
www.autozone.com
www.roversnorth.com
www.napaonline.com
www.autozone.com
www.roversnorth.com
www.napaonline.com
on
ORIGINAL: dillhole
How many miles on your truck, you may also need to replace your belt tensioner and the 2 idler pulleys, drprnds on your mileage.
esaycho
10-12-2005 03:24 PM
