What in the world is this under the TB??? Apparently it needs replacing.
#21
Yes thank you. I see that...
As of now the strangest thing is happening and I have a thought but I'm just not sure...
Once I go through the procedure the truck is fine at idle. As soon as I start to drive though the truck overheats and when I pop the top STEAM is coming out of the over flow tank...
So my question is this... For testing purposes I have been using 100% water in the cooling system. No mixture what so ever. Is this improper? I have been doing so because I don't want to just buy gallons and gallons of antifreeze/dex cool if my problem still persists.
Please advise... Going crazy.
#22
#23
#24
#25
...aye, a failed head gasket...
I'm researching what the possible symptoms are for that. I'm praying that it's not that but I guess there is some way to test that?
I thought if water was getting into the motor than I should see residue or something coming out the exhaust system... And why is that at idle the truck is fine? It's only when I attempt to drive it?
#26
#27
Yep. That combusion leak tester is available for rent at most of the larger auto parts stores. (you just can't return the fluid)
I still have my 1st gen Rx7 in my garage. That was my first toy and may someday make it back to the road. It is currently storing various LR parts on the hood and roof.
#28
MARSRover
06-22-2012 01:47 PM
