What year Discos have the CDL?
Is it just 04? Also, is it all 04 models? (i.e SE, SE7, HSE) Thanks.
04's - standard.
03's - nada. 02's - some equipped, some not. Not sure of range or dates 01's - equipped but without shifter 00's - equipped but without shifter 99's - equipped but without shifter D1's - standard 94-99 All info subject to correction and criticism. |
ok, i know this was discussed somewhere else, but i will just add it on here. i have an 03 discoII, if i want to add CDL, do i ned a whole new transfer case, or can i do it with the kit that is available? thanks.
94-99 D1's have it
99-may 02 D2's have the guts in the TC but need lever or 11mm wrench to click it on 04 D2's have it. |
newdisco...you can just but the kit and it will work. Will still need a shifter assymby of of a D1 or a 04 model.
94 to 99...have it 99 to 01.5 have capability but need shifter 01.5 to 04 need a kit and shifter or pre 01.5 CDL swap 04 has it with shifter |
After this weekend I'm convinced that having no CDL does not matter :)
Edit: provided your TC works. |
I have to agree. my 02 dosn't have it and have not needed it, wifes 01 has it and have not needed it. Healthy TC is all you need.
