Usually I could pick up a manual for wiring diagrams for my trucks at Napa/Autozone, but it appears they don't carry one for Land Rovers. Where can I find electrical wiring diagrams for a 2001 Disco?
Consider down loading a free Rave CD, best way to go.
UK color coding system may help you out too...
BS-AU7:
Black: All ground connections
Black/ Purple: Temperature switch to warning light
Black/ Green: Relay to radiator fan motor
Black/ Light green: Brake switch
Black/ Light green: Brake differential pressure valve to warning light
Blue: Headlamp connections
Blue: Headlamp switch to dimmer switch
Blue White: Headlight high beams
Blue/ White: High beam dimmer switch to high beam indicator lamp
Blue/ White: Dimmer switch to long-range driving light switch
Blue/ Red: Headlight low beams
Brown: Main feed from the battery. No switches or fuses
Brown/Yellow: GEN to volt. Regulator
Brown/ Blue: power feed to headlamp switch
Brown/ White: Ammeter to main alternator terminal
Brown/ Yellow: Long-range driving light switch to lamp
Brown/ Yellow: Alternator to 'no charge' warning light
Brown/ Purple: Alternator Regulator feed
Brown/ Green: Fuse to horn (No relay)
Brown/ Lt. Green: Windscreen wiper motor to switch
Brown/ Black: Horn to horn button (no relay)
Green: Ignition switch controlled wiring for auxiliary devices, eg wipers, flashers, etc
Green/ Black: Fuel gauge to fuel tank unit
Green/ Blue: Water temperature gauge to temperature sender unit
Green/ Brown: Switch to reverse lamp
Green/ Red: Direction indicator switch to left-hand flasher lamps
Green/ Purple: Stop lamp switch to stop lamps
Green/ White: Direction indicator switch to right hand flasher lamps
Green/ Yellow: Heater switch to slow speed on heater motor or for single speed motor
Green/ Gray: Heater switch to high speed on heater motor
Green/ Orange: Low fuel level switch to warning light
Light green: voltage stabilizer to instruments
Light green/ Black: Windscreen washer switch to motor
Light green/ Blue: Flasher switch to left-hand flasher warning light
Light green/ Brown: Flasher switch to flasher unit
Light green/ Purple: Flasher unit to flasher warning light
Light green/ Orange: Rear window washer switch to motor
Orange: Wiper circuit
Orange/ Black: Wiper switch to to motor parking
Orange/ Blue: wiper switch to low speed on motor
Orange/ Green: Wiper switch to high speed on motor
Orange/ Yellow: Rear wiper switch to rear wiper motor
Orange/ Light green: switch to rear window motor parking
Purple: Accessories fed direct from battery via fuse (Always live)
Purple/ Brown: Horn fuse to horn relay when horn is fused separately
Purple/ Red: Switches to map light, under bonnet light, glove box light and boot lamp when fed direct from battery fuse
Red: Tail lights, instrument lights, parking lights and side markers
Red/ Yellow: Fog light switch to fog light or front fog light fuse to fog lights
Red/ Blue: Front fog light fuse to fog light switch
Red/ Brown: Rear fog guard switch to lamps
Red Orange: Power to rear fog guard lamp fuse
Red/ White: Fuse to instrument lamp switch, Instrument panel lamps
White: Ignition circuit, no additional switches, not fused
White: Power to coil
White/ Black: Ignition coil to distributor
White/ Black: Distributor side of coil to tech impulse sensor
White/ Brown: Oil pressure switch to warning light or gauge
White/ Pink: Ignition switch to radio fuse
White/ Red: Ignition switch or starter switch to starter solenoid
Yellow: Generator connections wired through the ignition switch
Yellow/ Green: Dynamo 'F' to control box 'F' Alternator field 'F' to control box 'F'
BS-AU7:
