-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   where to clear the 3 amigos? (https://landroverforums.com/forum/discovery-ii-18/where-clear-3-amigos-22193/)
VikingDiesel May 24, 2009 08:59 PM
id like to know where I can delete my 3 amigos so i can see what will cause them to re-appear again. I am doing the my front brakes since there is a big squeal coming from them which is messing up my wheel sensors hopefully causing my 3 amigos. I dont wanna go to the dealership obviously
Spike555 May 24, 2009 09:03 PM
You either need a trip to the dealer or a indie shop with TestBook or T4 computer.
Disco Mike May 25, 2009 08:13 AM
The dealer will read but not clear the codes, find a small shop that has a scanner that can access the ABS and get them to do it. Fix the brake squeak first. If you throw a panic stop on a loose surface can you feel the ABS pulsate thru the brake pedal?
VikingDiesel May 25, 2009 09:13 AM
yea, for some reason I really dont feel that ABS pulsating actually but considering the ABS light is on to begin with, that means automatically the ABS wont work regardless since the light is on
Disco Mike May 25, 2009 10:24 AM
NO, not the case. When the 3 Amigo's are on, the ABS will work as long as it is not the module that is failing, the Hill Decent and T? won't work usually.
