Whining Power Steering, Already Flushed Fluid, Any More Advice?
Well, I was having some trouble with my disco making this low pithced whining noise, and it worsened when you turn the wheel. After reading some similar post on here I took what seemed to be the typical advice of flushing the power steering fluid and replacing it, and put in some additive. Afterwards i drove it home and it sounded fine. No noise what so ever. This morning I wake up and am driving to work and it sounds just as bad as it did in the first place. I was pissed to say the least. I don't own any tools or have a place to work on my car either so I took it to a shop and paid them 128 dollars to do this service for me. So now I am back to square one and a 130 dollars broker. So I am assuming that my pump is going bad and needs to be replaced, however I was hoping someone on here might be able to tell me if there are some other things I may be able to check out before I go drop 467 dollars to get a new pump put on. Please Help! I don't have that kind of money, and this just had to happen at Christmas time. By the way it is a 2003 LandRover Discovery 2 SE-7 with 63000 miles. Thanks in advance guys.
RE: Whining Power Steering, Already Flushed Fluid, Any More Advice?
Don't have ACE. And the noise has only just begun in the past 4 or 5 days. It is too loud to be normal I would say. The steering doesnt feel any different than it did prior to the noise, but the sound has got me worried. I just thought it wierd that the noise went away after the flush only to come right back again the next morning.
ORIGINAL: Spike555
Both guys with PS issues...have the water pump checked out, when the bearings start to go they will whine/squeal.
The whine can come and go, but if it steers fine then I would say it is not the power steering pump.
Sorry, I did not know that the power steering was making more/less noise while turning/full lock.
I would replace the serp belt next if you have not done so already.
After that I would do a PS flush again and then drive it for a week or two.
ORIGINAL: Spike555
