window switch drama.
I did a search and located a few different anwsers, maybe you guys can tell me the solution that works most often. Heres my situation. I have a 98 Disco I LSE, the rear windows will not go down or up with either the center console switches or the rear door switches. My heated seats buttons do work along with the front window switches in the console. Does this sound like it would be the sodder connections in the window ecm under the glove box?
-Tyler
-Tyler
on
RE: window switch drama.
You hit it right, it is the body ECU, most likely a cracked circuit board or a bad solder, both of which can be fix or you can go buy a good guaranteed used one from,
http://www.roverlandparts.com/index....S&Category=450
abran
08-05-2014 06:13 PM
AZRover
07-02-2012 06:43 PM
phillman98
12-04-2010 10:01 PM
miishmiish
02-26-2006 07:20 PM
