Windscreen wipers
Windscreen wipers
Hi,
I've just bought a 93 Discovery and I've notices its got a few issues.
The main one is that the wind screen wipers don't work and seem to constantly blow fuses. This one could probably be a loose wire somewhere but I'm wondering if this is a typical fault for discos? anyone have any ideas?
Cheers.
Cheers.
Check your under dash fuse panel for loose wires coming out of the back of it.
I would say it is a back switch but that should not blow fuses, I say that you have a short somewhere, that will be very hard to find.
Wait a minute, is the wiper motor any good? If it is seized when you turn the wipers on the motor will get hot and draw to many amps and blow a fuse.
Pull the wiper motor out of the truck and bench test it.
Is the fuse blowing immediately when you turn the wipers on or is there a delay? A delay would indicate that the motor is overheating like Spike suggested. If the fuse blows immediately then you have a short somewhere in the system. For a short I would check the wiring at the switch first. Any place where you have physical movement is a prime candidate fr a wire to short out.
Where are you located? Here in the states the Discovery didn't show up until 94, that's why I ask. More curiosity than actual need to know to help with the problem. How many miles on the vehicle? Any ideas about the maintenance history?
