Winter Oil
Old 09-11-2013, 06:48 PM
MeanSaleen's Avatar
They have 5W40 Rotella. I'd let it warm up a little before rolling.
I also see a lot of rotella 10w30 (Im trying to stick with dino oil over synthetic) That should be fine for the winter months no? Your input buzz?
  #22
Old 09-11-2013, 06:55 PM
As long as you are below 90F. But 10W40 would also work.
  #23
Old 09-12-2013, 07:24 AM
drowssap's Avatar
nothing a good 5 minute warm-up wouldn't cure.
  #24
Old 09-12-2013, 04:18 PM
AwannaD2's Avatar
From what Ive read It seems the synthetic Rotella is the better choice for the cold as far as minimizing wear on our engines during startup. The synthetics have a much better viscosity when cold than the dino oil and the same viscosity when at operating temp.
Id like to know that my goods are getting nice and lubricated in wee hours of the morning.
  #25
Old 09-13-2013, 11:27 AM
Chrisinhouston's Avatar
A pal was stationed in the Air Force in Alaska. Was so cold in winter that block heaters did not work for trucks parked inside what passed for shelters. They would drain the oil, and keep it in a big pot on an electric hot plate all night, then pour hot oil into truck to start.
Was in Turkey in the late 70's in the mountains in wintertime. The truckers just pull of the road to sleep and in the morning they light up propane stoves under the oil pan to heat things up!
  #26
Old 09-13-2013, 11:31 AM
drowssap's Avatar
ONE thing to remember about the rotella, its the diesel oil you want. Not just an oil by rotella.
  #27
Old 09-13-2013, 11:35 AM
jafir's Avatar
Originally Posted by drowssap
I think to remember about the rotella, its the diesel oil you want. Not just an oil by rotella.
True story. I'd run Mobil 1 turbo diesel oil in my D2 when it was on sale too. Nothing magic about the rotella brand, it just happens to be a good diesel oil.
  #28
Old 09-13-2013, 12:37 PM
Diesel oil is formulated for soot control. It keeps particles in suspension longer so your filter can trap it. The Rotella has a lot more ZDDP in the formula than most oils, that is a good thing for old flat tappet engines like the D1 and D2.
It won't make your truck sound like a diesel, and you won't get the mpg of a diesel. The EPA is probably tracking Rotella sales right now to narrow down the list of prime offenders.
cappedup
03-07-2015 07:49 PM
leadfoot
03-08-2014 10:46 PM
Roverrocks
01-01-2014 11:45 PM
nuclearw
11-13-2013 11:33 AM
kpl1228
01-04-2012 08:58 AM
Quick Reply: Winter Oil
