wont start
Does your fuel pump come on?
Put your ear to the floor in the cargo area and have a friend turn the key to the "ON" position, you know the one, the one where all the dash lights come on but NOT the one where you crank the engine over.
Do you hear the fuel pump come on?
It should come on and run for 15-30 seconds and then shut back off.
on
What I would suggest is to clear out the rear cargo area, lift the carpet, mats and pad or whatever is left in yours. There is a black metal plate screwed into the floorboard. Remove the plate (6 screws I think it was).
You should then be looking directly at the top of the fuel pump/sending assembly. There is a connector on the left side. You can check there for the 12 volt input to the fuel pump. If you do have the 12 volts, the fuel pump is bad.
I recently replaced mine due to a split in the line at the plastic top of the fuel pump sender assembly. A brand new ProLine assembly for my 97 was only $105 from Rovers North.
And no they are not interchangeable.
http://www.roverparts.com/TechTips/k...ons_system.cfm
I bought my fuel pump at AutoZone last year, $450.
Check locally for a fuel pump too and see if you can save on shipping.
The hardest part is getting the retaining ring off.
