XYZ Neutral Safety Switch
FYI Land Rover Discovery II lovers, I found a NEW YXZ Neutral Safety switch at autozone for my 2003 Disco for less than $300. It will not show as XYZ switch, it is listed as Duralast/Neutral Safety Switch. It took me a long time to find it.
I found a used one on e-bay for $100, incorrectly listed as being compatible with my truck; when I put it in, it burned my transmission solenoid and it became a very expensive transaction for me. You may be lucky enough to find a used one that works and is compatible, but I advise to pay the extra $100+ and have peace of mind and a full warranty :) |
Part number, please?
Part Number: LU408
Part Number: LU408
Advance Auto Parts also carries a LU408 for the DII for $354.
You can get it from AutoZone for $233.59. Use coupon code: CHOOSE20 - Save 20% On Online Ship-To-Home Orders $100 Or More. Coupon ends 1/31 |
You guys don't know you're born ;):eek: the kosher LR OEM XYZ switch this side of the pond is circa £450 = $675. :eek: ouch!!!! that's why I refurbed mine and it works like a dream. Cost me less than £1 :)
PS I found this; This is basically the same as I did but mine is a later less complex switch internally, externally it looks identical. Bearing in mind you have to remove this switch to replace it in any event so whilst you are doing that you may as well refurb it ............ nothing ventured nothing gained :) Another issue, be sure to add a length of tube onto the AC drain and reroute it away from the XYZ switch as it discharges on top at present. Rebuild D2 ZF Selector Switch UHB100190 - Australian Land Rover Owners |
I never understood where the "XYZ" slang came from but it seems to me that NeutralSafety Switch's in general are expensive. My former 1999 Saab 9-5 had a faulty neutral safety switch which made it so my rear brake lights would not work. Had a hard time getting anyone to inspect the car because of it and of course the part is no longer available though if you look hard enough online you can find one for several hundred bucks. Saab enthusiasts on the forums were having a simular discussion about rebuilding their switches to! Kinda wierd that 2 completly different vehicles have the same issue and solutions...
1 Attachment(s)
It's more than a neutral safety switch. The transmission is electronically controlled, and the switch tells it which gear you are in. There are 4 outputs, w, x, y, and z is how they are labeled in the manual.
Attachment 24491 |
Originally Posted by jafir
(Post 502021)
Attachment 24491 |
| All times are GMT -5. The time now is 04:59 AM. |
