XYZ Switch, p0705, Check Engine Light
Hello all,
I get a p0705 every so often and it’s followed with a CEL. My question is, would a xyz switch cause a check engine light? I just bought a new switch and I plan on installing it however I want to be sure that it’s the solution and not something else. The rod that holds my switch is so stuck that I recently sprayed it with penetrating solution and I’m scared of snapping it when swapping the switches. I’m also considering changing the transmission fluid even though I’m told not to yet because it could open a can of worms. Whenever the flashing M and S lights come on, I just turn the car on n off and it usually goes away however the check engine light does not. I don’t get any other codes but that p0705. any advice here would be greatly appreciated before I start swapping things out blindly. thank you |
Likely unrelated. P0705 is misfire on #5. Read my misfire sticky at top. Your flashing m&s is likely low voltage.
Originally Posted by Extinct
(Post 946343)
Originally Posted by extinct
(Post 946343)
likely unrelated. P0705 is misfire on #5. Read my misfire sticky at top. Your flashing m&s is likely low voltage.
Yes, sorry, working off old memory, I was thinking P0305 - what is P0705?
(Post 946377)
| All times are GMT -5. The time now is 02:17 AM. |
