please help me figure out how to fix this
Land Rover Discovery Sport SE 2019
Please help me solve this. It will automatically put me in park Won’t shift right Sometimes won’t go in gear Here are my codes: P0850-00 Park/neutral Switch Input Circuit - No Sub Type Information U0402-68 Invalid Data Received From TCM [U0402] - Event Information P26CB-72 Variable Coolant Pump Performance/stuck Off - Actuator Stuck Open U0402-68 Invalid Data Received From TCM [U0402] - Event Information P26CB-72 Variable Coolant Pump Performance/stuck Off - Actuator Stuck Open Please help thank you. |
Did you figure out the problem?
I’m having the same issue. I got a code: P26CB-72 Variable
Coolant Pump Performance / Stuck Off. Any insight would help. Thanks |
| All times are GMT -5. The time now is 02:58 AM. |
