engine swap
what other engine fits a 1995 range rover
RE: engine swap
Could you ram a new 4.2 supercharged v8 in there?
I think shoving one in my d90 would be nuts...lol.....but to be honest, i have no actual info to help you. Just thoughts [8D] |
RE: engine swap
these drop in
3.9 4.0 4.2 4.6 |
RE: engine swap
ORIGINAL: llesra these drop in 3.9 4.0 4.2 4.6 |
RE: engine swap
you can use your existing heads and ecu and bolt up a 4.6. I think you have to shave the front cover and a few other things, but you can use a 4.6 on a 4.0 system. Check out this link.......
http://home.twcny.rr.com/eeibooks/rover/engine.htm |
RE: engine swap
Yeah, be thankful you're not trying to add a bigger engine to a new vehicle. Oh the pain.
RE: engine swap
ORIGINAL: okdiscoguy you can use your existing heads and ecu and bolt up a 4.6. I think you have to shave the front cover and a few other things, but you can use a 4.6 on a 4.0 system. Check out this link....... http://home.twcny.rr.com/eeibooks/rover/engine.htm However, in the end, you will be aggravating the problem that caused the failure shown on the link above unless you remap your fueling with a Tornado chip and/or buy one of the new comcast blocks. James |
