5.3 LC9 engine / 6L80 trans.Discovery 2
2001 Discovery. Soon starting on swapping drive train. 2013 LC9 5.3 engine &6L80 trans.
https://cimg4.ibsrv.net/gimg/landrov...d270cbfe81.jpg Just waiting to start. https://cimg4.ibsrv.net/gimg/landrov...a3cd3cc31d.jpg Old one out soon. https://cimg8.ibsrv.net/gimg/landrov...c2cef98037.jpg LC9 https://cimg9.ibsrv.net/gimg/landrov...d5cbfa8cd7.jpg 6L80 https://cimg6.ibsrv.net/gimg/landrov...5ef73cced3.jpg https://cimg8.ibsrv.net/gimg/landrov...b239b6a47d.jpg |
This is the plan for my D1. How much did the engine/trans set you back?
Originally Posted by dos531
(Post 757630)
I'm looking to do the same swap (LC9 + 6L80). I'd love to hear more about your process! How did it go? Any key words of advice to share or critical parts you used? It would be amazing to seem some install pictures (above and below).
This will be my second LS swap so I'm familiar with the broad strokes but always prefer to follow in the footsteps of others. |
Originally Posted by BoulderCharles
(Post 775003)
I have completed my LC9 swap and wanted to share a few things, just in case they are helpful.
(Post 791676)
Thanks Again. |
I didn't document my build in a threat but I'm happy to answer questions (and a picture below).
I'm working with Nick at RW Engineering for the CAN-bus gateway. It's a great solution but we are still sorting out a few things that are likely specific to the 2004 D2. Doing the diagnostics, programming, and troubleshooting to recreate that gateway will be a lot of work (and the Rover documentation sucks for really complex work). I recommend doing the diagnostics to figure out the right signals for the Rover's gauges/sensors before committing to the DIY approach. Nick suggested that getting some of those gauges to work was a real pain. That said, I'm not a programmer so it all seems difficult to me. Are you keeping DoD and VVT? I swapped to Summit's stage 1 cam to get rid of that stuff. https://cimg8.ibsrv.net/gimg/landrov...9e4798d7fe.jpg |
Also, while you are at it you may consider moving the radiator forward a bit. It's real tight and makes it harder to fit the intake piping. I had to use the flexible piping, squish it into a bit of an oval, and then tie it into the cover to keep it from the accessory belt.
(Post 791755)
I'm working with Nick at RW Engineering for the CAN-bus gateway. It's a great solution but we are still sorting out a few things that are likely specific to the 2004 D2. Doing the diagnostics, programming, and troubleshooting to recreate that gateway will be a lot of work (and the Rover documentation sucks for really complex work). I recommend doing the diagnostics to figure out the right signals for the Rover's gauges/sensors before committing to the DIY approach. Nick suggested that getting some of those gauges to work was a real pain. That said, I'm not a programmer so it all seems difficult to me. Are you keeping DoD and VVT? I swapped to Summit's stage 1 cam to get rid of that stuff. |
| All times are GMT -5. The time now is 11:54 PM. |
